Ir para o conteúdo principal
Budget 15" laptop series released by HP.
261 Perguntas Visualizar todos
Hard drive is no more available
Hi,
Regarding Repair Guide: HP Pavilion 15-bk020wm Hard Drive Replacement HP Pavilion 15-bk020wm Hard Drive Replacement :
I think the laptop and also the hard drive is no more available (only used one).
To replace the hard drive which actual model could I use?
Thanks.
Update (11/27/2018)
Model number: HP 762990-005
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Please give us the make and model number of the drive.
por
Please see my answer below. Thank you.
por
Adicionar um comentário
2 respostas
Solução escolhida
That looks like a standard 2.5” SATA Drive. I suggest you buy this SSD as it will improve your device performance. It should work with your laptop.
Esta resposta foi útil?
Pontuação 5
Don’t worry about replacement part numbers.
Any 2.5” drive will work, but hey replace with any SSD drive.
Your computer will run better than when it was new.
Pontuação 2
1 comentário:
I agree with you.
por
Adicionar a sua resposta
Jorge será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 385
