Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
Can't Set Time & Date Automatically
Hi,
I can’t seem to configure the Time & Date on my iPhone 5C. My SIM is working fine and I get full signal, although when I choose to set time automatically it just hangs on setting the Time Zone. I just get the loading animation next to Time Zone and it never seems to load.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Donald,
It may be that it’s having trouble with location services. You can try to toggle some settings off and on to see if it will clear it. Also check if location services is even turned on.
Toggle:
Settings>General>Date & Time>Set Automatically (off/on)
Check if location services is on:
Settings>Privacy>Location Services (off/on)
Check if time zone has access to location services:
Settings>Privacy>Location Services>System Services>Setting Time zone option
Esta resposta foi útil?
Pontuação 1
5 comentários:
Hi Arthur, Thanks for the suggestion. Unfortunately I have already tried all of these and non of them seem to work. I have also tried a Network Reset and a Full Factory Reset with no luck.
por
I'm sorry to hear that! I wonder if at this point it's a hardware issue. We'll see if anyone else chimes in.
por
Hi Donald. A bit late but did did u manage to fix your issue? I'm having the same problem.
por
@rishkadavids It's a relatively common hardware issue on 5Cs. Impacts on the iPhone creates micro-fractures at the WiFi IC. It can be fixed, although not absolutely reliably, by a reflow or better a reball of the IC. Given present value of a 5C such a repair would cost more than a working 5C iPhone.
por
How set time and date iPhone 5
por
Adicionar a sua resposta
Donald será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 36
Ao todo: 1,432
