Ir para o conteúdo principal
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Replaced logic board and still having the same no backlight issue.
Replaced the logic board in the display with no difference. Pretty sure I can rule out logic board failure. No backlight but the display still has a picture with flashlight head closely. And the camera, usb, and ethernet still work the same. The charging for the older macs still works as well. Would it be the power supply not applying power to the backlight or the LCD? I have had stints of perfect operation in short bursts regardless of which logic board, but only after lots of messing about with plugging power in and removing it. I really don’t have another resource for information like this.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Is it the controller board on the LCD itself?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
The LCDs are quite common to fail on these unfortunately, so it’s likely the LCD controller board.
In cases where we have the same symptoms, we’ve found it to either be main logic board or LCD panel.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
huntertrainboy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 100
