Ir para o conteúdo principal
Is the LCD screen all I need?
I had an accident to where my iPod Touch 2G screen was cracked but it still worked so I kept using it. I guess once its cracked it can only be dropped so many times before it gets worse. Now my iPod cant recognize when I touch the screen. The picture and color is still good and still clear, nothing out of place or lines on the screen, it just can't read my finger touching it.
I remember reading up on something saying there is like 3 layers of screen in an iPod so im confused....is the LCD replacement screen all I need to get to fix my problem?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
You will need a digitizer, not a LCD, the LCD is the part with the picture, which is working fine. The digitizer is the glass piece that you touch with your fingers. These are very easy to find, i recommend purchasing one with the frame and homebutton already attached.
Esta resposta foi útil?
Pontuação 1
Hi there, what James said is correct. You will need to replace your digitizer. I recommend buying it from ebay.
For the digitizer, click here
Hope this was of help to you and goodluck!
Pontuação 0
Adicionar a sua resposta
bridget será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 716
