Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1200 Perguntas Visualizar todos
The Phone will not activate!
Hey All
ok i have an iPhone X and i restored the the phone to 12.1
since then i can not activate the phone.
Find my iPhone has been switch off before i don’t the restore its off on the system and its unlock to any network.
i have Dfu restored also with recovery on countable times
when i connect to wifi to active i get the error
“Your Phone could not be activated because the activation several is temporary down”
connect throw iTunes i get the error
“THE iPhone could not be activated because the activation information could not be obtained from the device.
i have tried other sim cards, it shows they get signal in top corner.
the phone was working with the sim card i used before.
Anyone know a way around it?
it just won’t activate
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
So, you are saying it works with other SIM cards but won’t work with a particular card? That tells me that the particular card that’s not working has failed. Get a new SIM card and it should be fine.
Esta resposta foi útil?
Pontuação 0
4 comentários:
no bro, it doesn’t activate with no sim card.
the phone will not activate.
por
"i have tried other sim cards, it shows they get signal in top corner'." What is that about then?
por
I have the same problem. I get a signal in the top right corner of the screen. I called my carrier and activated a new Sim card and I'm still getting the same error message
por
Try to dial *#06# and see if the device returns its IMEI.
por
I’m having the exact same problem, please help :(
Pontuação 0
Adicionar a sua resposta
Blanco será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 550
