Ir para o conteúdo principal
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Why won't my lcd work?
I just attempted to replace the lcd and digitizer on an Ipad Mini 2 LTE. I connected everything correctly, but the lcd won’t turn on. The Ipad is recongized in Itunes. I would try to back it up but I can’t allow the computer to be accepted. I tried 3 three lcds. The previous broken one lit up, but was gray and orange with line. Is there some fuse burned out on the Ipad.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Let’s rule out a backlight issue. Shine a bright flashlight onto your iPad’s screen at multiple angles and see if you can make out any pictures on the screen.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I have tried this a few times and none of them have worked.
por
That sucks! I am not the iPad expert around here so don't give up hope yet. @refectio knows iPads better then I do, maybe he will drop by and suggest something!
por
Adicionar a sua resposta
Isaac Stromberg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 128
