Ir para o conteúdo principal
Skullcandy Crushers are packed with 2 drivers, the Sensation 55™, and the REX40™, delivering excellent sound quality and bass you can feel. The product was released on March 20, 2013 and goes by the model number S6SCFZ-072.
16 Perguntas Visualizar todos
audio cuts out to my wired headphones may be problem with aux jack
my headphones will cut the sound from the wire into the headphones if i touch the wire that goes into the headphones it will cut out audio until i wiggle the wire around the sound will cue in but if i move the slightest it will cut out my friend said its a problem with the headphone jack the wire its self it fine we tested it on many other devises and there are no problems
Esta é uma boa pergunta?
Pontuação 2
1 comentário
ive also noticed the headphone jack is a bit loose on the circuit board
por
Adicionar um comentário
1 resposta
Pergunta mais útil
the headphones aux port was loose on the board some hot glue will help keep it in place with out damaging the circuit board
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kenzie Duren será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 2,200
