My DS lite won’t charge
My ds is fairly old and it hasn’t been charged in years. I tried charging it again but the orange light won’t even show. My charger is new but nothing happens.
Esta é uma boa pergunta?
This could either be a
Guia
Nível de dificuldade:
Fácil
1 - 5 minutes
Guia
Moderada
25 minutes - 2 hours
Guia
Muito difícil
45 minutes
Esta resposta foi útil?
I had a similar issue with my old DS Lite, I noticed while looking into the charging port that it was pretty bent back, I got a flat head screwdriver and pushed it back into place. Although I wouldn’t recommenced using a Flathead screwdriver, I would recommend using a spudger if that’s the issue.
It could be the battery, but if there’s no light at all then I don’t think so, as a DS Lite even without a battery would still make a light when charged.
Good Luck with repairing your DS Lite!
Now that you mention the battery port, I just noticed that it is a slight bit crooked. Maybe that little thing in the middle could be the problem.
I had similar issue too. I have 2 DS Lite, both of them still working and can be charged but recently, one of the are not charging anymore (the orange light didn't even lights up). I can rule out charger issue (since the other one can still be charged as usual) and battery issue, since it can still be turned on, just not charging anymore.
I hope this worked for you!
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 3,520
