Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Earphone jack not appearing in system prefs.
My daughter has this problem where she is using her Aux. cord to add audio to her sound system to watch movies using an HDMI in tandem to her TV set up. She has recently encountered a problem where the sound won’t work through the earphone jack anymore. She’s tried inserting it in and out, turn and twist and even went to systems prefs and didn’t even see the option for an output via earphone jack. The only thing that works it the external speakers on her MacBook Pro. I have a suspicion the earphone jack is blown and the only fix is buy another motherboard as this is irreplaceable otherwise. Any suggestions and insight would be greatly appreciated. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try a clean installation of macOS to rule out a software problem.
If it ends up being hardware problem you can still fix this without replacing the logic board. You can take your logic board to a micro solderer and have them desolder the old headphone jack off the board and solder a new headphone jack onto the board.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
gstanton será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 38
