Ir para o conteúdo principal
Repair guides and support for a wide range of small engines.
103 Perguntas Visualizar todos
compression release malfunction on craftsman 24HP Twin?
I have Good fuel, good spark, both intake and exhaust valves function on both cylinders (I removed the valve covers and observed them),  I have good compression on RH cylinder, no compression on LH cylinder.  Engine will not start.  Ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
No compression on LH cylinder sounds like major issue with that cylinder. Cylinder leakdown test may reveal if it is losing compression past valves or piston rings or head gasket. However, most DIYers don’t have a leakdown tester.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Good compression on RH cylinder. None on LH cylinder. I can get a compression tester. Question: with a 2 cylinder and good compression on one cylinder and none in the other, wouldn't it still start? Just run really ragged?
por
Adicionar a sua resposta
Harry Laclair será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 78
