Ir para o conteúdo principal
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 Perguntas Visualizar todos
Why are there dark sections of picture on TV?
I have a Vizio E60-C3. A few sections of the picture grid have become darker then the rest of the screen. I'm not sure if this is a backlight gone out or board issue. Was hoping for some advice on how to fix since the tv works fine otherwise.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This appears to be a couple of bad LED strips. This set has 2 strips per row. From the picture provided, there appear to be 2 strips out on the upper right and an entire row of 2 strips out in the middle. This unit has a total of 12 strips (6 per side). You can either purchase 4 strips and replace the defective ones, or purchase the individual LEDs and replace them on the defective strips once you locate the dead ones. Note: 1 bad LED will prevent the entire strip from functioning.
Dan
Esta resposta foi útil?
Pontuação 2
2 comentários:
Okay that's what I had thought, any idea what the replacement strip is and where I can buy it? Also if there's any how-toy's for replacing defective strips? Thanks!
por
One example of a strip is here: https://www.ebay.com/itm/VIZIO-E60-C3-E6...
Search Ebay using the following: "Vizio E60-C3"
You can watch the video from Shop Jimmy here: https://www.youtube.com/watch?v=VP7iNYFA...
Parts can be obtained from Shopjimmy as well.
por
Adicionar a sua resposta
Daniel Marchetti será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 34
Duração total: 12,811
