Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Display has a vertical band on left side and white screen
I haven’t seen this one before. The left side has a black vertical band and the rest of the screen is white, Customer said the machine was working fine and she woke up to this in the morning. No spills, no drops.
It will generate a picture on an external monitor. I know how to make the external monitor the active screen from the original screen but have forgotten if there is a way to do it if you can’t get to the original display @danj can you help on this one?
UPDATE
very close examination revealed a pin hole size impact
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Solução escolhida
That’s a broken LCD panel. Command+F1 should toggle the screens.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I'll expand a little on the broken LCD diagnosis, in the bottom right corner of the black band, that jagged corner is a telltale sign of panel damage versus some sort of signal or digital issue.
por
Joe you were correct. see update to post. It was so small I missed it and I believed my customer.
por
Adicionar a sua resposta
mayer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 2,046
