Ir para o conteúdo principal
Laptop/tablet híbrido fabricado pela Microsoft. Lançado em novembro de 2017.
Sticky Keys from Drink Spillage (Surface Book 2)
Recently, I opened a Pepsi can and it sprayed over the left side of my keyboard. My computer is fine, but the left side has sticky keys and the trackpad doesn’t click as much as well. What is the best way to clean the keyboard?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
If the liquid spray is only on the keyboard then you can try using a dampened cloth to clean around the keys. Do not use more water than needed to wipe the surface. You can also try using cotton swabs also slightly damp to clean around the keys. If this does not fix the problem then consider replacing the keyboard.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jacob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 16
Ao todo: 1,467
