Ir para o conteúdo principal
Why does my truck shut-off when I hit my gas pedal?
My truck normally needs a spray of starting fluid to crank and then once I shift into gear it tends to shut down or idles for (4 or 5 mins) and then it cuts off or soon as I hit the gas to rev the engine or drive it shuts down
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
This sounds like a MAF (mass airflow sensor) related problem. You should be getting getting a "check engine" light on your dash. That it to Auto Zone and ask them to do a free computer read on your engine and see if the problem shows up. Here's some information on the MAF failure symptoms: http://www.ehow.com/about_5382536_mass-a...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ykene Ruffin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 8,569
