Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
Logic board not working
what can cause the logic board to just stop working?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
First off you need to check that its the logic board and not any of the components like dock or battery. Try your board in a friends case or Take the board out, check your connections and while you're there check the output on the battery. Use a multimeter on pins 1+4 should be 3.7mAh for a fully charged battery, but not working at about 2.2? If it's dead then replace it. Usually a battery will give warnings like freezing up, crashing, not holding charge for long.
If your battery is good then you need to check the dock connector for dirt/damaged pins etc that are stopping it from charging or being recognised. replace it or just that flex.
After that it gets a whole lot more tricky..
Esta resposta foi útil?
Pontuação 4
8 comentários:
i have another working 3gs that needs a backlight coil i tryed the battery from that in it and it still didnt turn on and i also swapped docks and still nothing
por
Ok I've confirmed it's not that battery or the dock so it has to be the logic board how do I fix it? is there something on the board I need to replace?
por
check the fuses near where the battery contacts are, also check connector 4 on your motherboard. then it's power ic
por
sorry pollytintop could you explain a little more detailed?
por
Jared, I think that pollytintop may refer to the fuses as shown on the pictures at this question Won't turn on after attaching to car charger
por
Exibir mais 3 comentários
Water damage, drop damage, electricity damage (getting shorted out), old age, and many more reasons.
Pontuação 1
3 comentários:
ok my 3gs just stopped working out of the blue no drop water damage nothing what could be wrong i replaced the battery and still nothing
por
not recognised in itunes? not charging? no display?
por
all of the above
por
Adicionar a sua resposta
Jared será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 2,857
