Ir para o conteúdo principal
Won't charge up at all
I have a 3rd gen shuffle, and it won't charge. Does it need a new battery,,,or is there another problem that I'm not "seeing"? I've already replaced it, but was wondering if a new battery might get the thing up and charging again. Any input?
Thanks!
Esta é uma boa pergunta?
Pontuação -1
2 comentários:
when you say you already replaced it, what are you referring to? The battery?
por
I replaced the shuffle with a new one because I needed it - but if the old one, has a chance at a new life, I just want to give it a try - as I'm sure that anybody would - why let it sit around if it may need a battery? Right?
por
Adicionar um comentário
2 respostas
I would think that a new battery night be a great start. It is easily possible that the battery is at the end of its lifespan. Give it a try by following this Guide. Just remember it is not an easy task, but definitely doable. Good Luck.
Esta resposta foi útil?
Pontuação 0
can i charge my ipod 3rd generation with my computer
Pontuação 0
Adicionar a sua resposta
JerseyJeepGurl será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 6,237
