Ir para o conteúdo principal
Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance. Released in 2012
Card slot damage issue
I’m pretty sure I have a damaged card slot due to a damaged card that I pulled out. A metal pin fell out that did not belong to my card. I can still put cards in my camera however I get an error message every time I put any card in the slot now.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sadly, the SD card slot in your camera is part of the motherboard, so unless you can do fine SMD soldering, you’ll have to get a new motherboard or have someone who knows how to solder SMD components do it.
The replacement card slot itself is only about $7 on eBay, but requires fine soldering.
A replacement motherboard will run you about $48 on eBay, requires no soldering, and has a replacement guide on the device page.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kylie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 467
