Ir para o conteúdo principal
D-Link DCS-825L is a HD Wi-Fi Baby Camera.
What should I do if my WiFi is not connecting to the camera?
I can’t get my WiFi to connect to the baby camera, what should I do?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
student question
por
Adicionar um comentário
1 resposta
Not Connected to Specific Wi-Fi Network
Make sure that your phone/device is connected to the Wi-Fi Network that is specific to your Wi-Fi Baby Camera (called “myBabyCam-xxxx”). The “xxxx” part of the Wi-Fi will be specific to every individual Wi-Fi Baby Camera and is located on the label on the back of the Wi-Fi Baby Camera as well as on the back of the quick installation guide.
You have the Wi-Fi turned off on your phone
Go to your phone/device’s settings, select Wi-Fi and check to see if your Wi-Fi is on. If not, switch the Wi-Fi on.
The Baby Camera is not turned on.
First, check that the Wi-Fi Baby Camera is plugged into an electrical outlet. If it is, press the power button located on the front, upper right side of the Wi-Fi Baby Camera.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alexis Clopton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 366
