Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
How to delete videos?
I went crazy when I got my ipod cause it had so much space, so i downloaded a huge amount of videos.
it still has lots of space but i wanna delete them. help D:
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I don't really have a solution I just wanted to say something I just try to add some photos but with doing that I took up most of iPod data,I went into panic mood wondering what I was going to do but thank good I came across this...it help me out big time thanks so much...
por
Adicionar um comentário
2 respostas
Solução escolhida
If you want to delete the actual videos, delete them through itunes. If you want to keep them, but delete from ipod, you can uncheck the sync all videos box under videos tab in itunes, then select which ones you want to sync.
Esta resposta foi útil?
Pontuação 1
Well, the simplest way is that you go to the Videos app, then slide to the left on the video you want to delete (same works with Mail, and few other apps like iBooks) and a delete button (red colored) slides in to the right. You click the button, and your video gets deleted.
Then in future, if you don't want to sync that video again,
1> Delete from your iTunes library OR
2> Uncheck 'Sync all videos' under the Videos tab in iTunes. Then it will not sync the video further, and you are left in peace to sync the desired videos.
Pontuação 1
2 comentários:
Fantastic I have spent 2 days trying to find a suitable answer and switched the question to google .…great answer and didn't need to involve iTunes which is not on my desktop XP. I have XP as desktop, older iPod and newer iPad so am constantly learning how to remedy things for myself. Much thanks
por
hahah, i completely understand! you needn't thank me, i'm just glad that this helped you. have a nice dayyy. c:
por
Adicionar a sua resposta
Afroza será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 19,402
