Ir para o conteúdo principal
Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
How to reset SMC on the 2018 MBP?
Instructions given on apple website at the link for T2 equipped devices are simply not working
https://support.apple.com/en-us/HT201295
The device simply boots up on attempting any of the 2 given combinations.
Please help
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Can you explain what you are trying to reset. The more detail the better.
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Here’s a guide on how to reset the SMC and the PRAM on your MBP. Hopefully it will work for you. If not, maybe @danj can assist you better if you provide more detail.
How to reset the SMC, PRAM and NVRAM on a MacBook Pro Touch Bar 2018
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you Aaron. Yes, I attempted that, but the systems always boots up during the procedure, actually within 2-3 seconds of attempting any of the 2 alternatives
por
Okay, hopefully Dan will be able to help you further. Sorry about that!
por
Press Shift + control + option button with power at the same time and release after 60 seconds altogether and continuously watch the light on the magsafe it will change color of led for a short duration of time indicates SMC reset has been successfully done
Pontuação 0
11 comentários:
Hello, and thank you for the kind reply.
This may work on older models, not the new 2018 with the T2 chip.
Also, And these models do not have a MagSafe.
por
Is your battery detachable or not or with touch ID
por
Systems with a T2 chip are very different than the older systems. Some settings are just not resettable. Depending on what the issue is we may need to use a different way.
por
Yes, I realise that systems with T2 are different, and therefore requiring a different procedure for the reset. I followed the instructions on apple page for systems with T2, that Aaron also posted. but this is not working. the system simply boots up 2-3 seconds when attempting any of the 2 alternatives. That does not sound right
por
SMS - What are you trying to re-set?
por
Exibir mais 6 comentários
Shift+control+option with power button
Pontuação 0
Aaron, I did this but it won’t restart. It was having issues charging. It just had a blinking red dead battery in the middle of the screen even though it was plugged in. I reset the SMC... and it never turned on and now doesn’t respond at all, I don’t even have the blinking battery anymore.
Pontuação 0
1 comentário:
@bpress - You really need to create a fresh question here with all of your systems details.
por
Adicionar a sua resposta
SMS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 2,275
