Ir para o conteúdo principal
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
24 Perguntas Visualizar todos
Model PSX3 tire inflator won't turn on, other functions have power
PowerStation model PSX3 has both tire inflator and jump starter functions. It also has a work light. The inflator had been working fine, but now the push button switch has no effect. Seems as if an electrical connection has been broken. The work light functions perfectly, so there is power available. Inspection of the interior wiring didn’t reveal anything obvious.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
my PSX3 compressor has started to run very slowly put-put-put...can that be fixed?
por
Adicionar um comentário
1 resposta
Solução escolhida
david barkman  it sounds like a bad switch (mechanical failure). If you can disassemble it, check the switch and you could always try to replace it. We would need to see what it all looks like in order to give you more details. You can always post some pictures so that we can possibly provide you with a more precise answer. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
1 comentário:
Everything works on mine except it doesn’t seem to charge. Light works and compressor works .
Have stripped it down and found a capacitor and resistor burnt out. Can see the capacitor values but there is no way of reading the resistor value. Any idea where I could get a circuit diagram please?
Thanks
por
Adicionar a sua resposta
david barkman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 1,680
