Ir para o conteúdo principal
Why is my phone not switching on?
its actually nokia 6.1 plus not nokia 6… its a new phone . I was using it on low battery and then suddenly found a bug on the screen . So I restarted it but it is not switching on now!
someone pleeeeeeaassee help
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My Nokia 6.1plus battery does not charge.
Is there a problem with the charging board?
Is this the charging board Nokia 6.1 plus his original ?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello,
Try pressing the power+volume buttons to hard reset the device in case it doesn’t work please take the phone to the nearest service center to get a closer look at the issue.
Hope this helps….
Esta resposta foi útil?
Pontuação 2
1 comentário:
Greatly appreciated your advice! It worked. Thought I was sunk ... and looking around for a pro until I read your advice.
por
Adicionar a sua resposta
Eeshdeep Singh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 1,040
