Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone completely dead after water damage
Hi, im trying to get a phone to power for a friend who needs photos of a relative who sadly passed away. 4 caps under the nand were shorted to ground but iPhone would not draw any current so I removed the u7 power management ic and those shorts have gone. C330 was still shorted so I removed u3 ic thinking it would clear it but it has not any ideas anyone? The phone was water damaged and ive ultrasonic cleaned it. Also are these chips interchangable or do I need the exact same code on the chip?
Regatds
Andrew
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If I remember correctly the shorted caps near NAND are okay to be removed (their shorted to ground anyway so they would need to be replaced) if you just need to get data off the phone.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Already removed u7 and u3 ic's after removing them all the shorts I could find apart from C330 are gone
por
Adicionar a sua resposta
Andrew Robey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 38
