Ir para o conteúdo principal
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
79 Perguntas Visualizar todos
How can I fix my flashing screen (TI-84+CE)
My calculator seems to have decided to no longer likes me, and is having startup issues.
It is stuck on a flickering white screen. I can’t turn it off. It doesn’t seem to be turning off on its own. I’d prefer to not have to completely wait for it to drain considering that I just finished charging it yesterday. The calculator does not seem to fully load at all and does not appear in the TI Connect CE program when plugged in to the computer. This is my personal calculator and I’d really like to have it fully working again, and if possible, salvage the programs I have on it. Is there anything I can do, short of buying a new calculator? Or is there a factory reset feature available anywhere I can use?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Try doing the recovery techniques listed on the guide I have linked to below. Hopefully one of those techniques will work for you.
TI-84 Plus CE Recovery Techniques.
Esta resposta foi útil?
Pontuação 8
4 comentários:
@thelastmill This problem was solved compliments to your wonderful guide, thank you!
por
Performed a hard reset on the calculator by clearing the ram using the button on the back and just redownloaded my programs. The slideshow above is also extremely helpful. Thanks!
por
@ahvey Glad it was helpful! Happy fixing!
por
I'm glad it was useful! :D
por
Adicionar a sua resposta
Matt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 28
Últimos 7 dias: 251
Últimos 30 dias: 776
Duração total: 21,983
