Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
Why is the battery different?
I followed the steps for battery replacement and was able to remove the battery. I place the new battery in and began to screw it in. I was able to screw one in (5.2 mm), but when I attempted the next one (13 mm) there was no entrance to screw in. Why can’t I screw this in? Why is this battery different? Is it better or did I get the wrong type of battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Confirm the model number on the battery with the old battery, if it’s different make sure you ordered this battery. If not, you might be able to call the manufacturer and say you got the wrong battery. If it is the same, make sure you’re installing it right, or the battery is made for a different MacBook even if the battery is labeled for yours. (Personally I would just put the battery in, make sure it works, and if it does just leave the screw out, but that’s probably the Nerf Modder in me speaking)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joshua Reed será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 37
