Ir para o conteúdo principal
O Asus ROG Strix GL702VM-BHI7N09 é um computador gamer lançado pela Asus em janeiro de 2017.
What's wrong with the GPU?
Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.
I’ve tried a fresh install of Windows, a different drive that I know is fine, different NVIDIA drivers. So I’ve narrowed it down to the GPU.
I’ve done some runs of Furmark, and each time, when it gets to >75C it usually blue screens or freezes with blocks/stripes of green/white/purple, and if it doesn’t do that on its own, a reasonable tap on the keyboard where the GPU chip is causes it.
Is this a sign that it needs BGA reballing by a repair shop, or is it a more serious less-repairable issue?
Thanks in advance for any help :)
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Joe McKinnon try some GPU throttling and see if it makes a difference. Root cause for this is poor airflow to keep things cool. https://rog.asus.com/forum/showthread.ph...
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Yep, “Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.” thats a sign of a dying/deadGPU. If the GPU in this machine is modular and can be replaced it is a simple and relatively inexpensive fix if you have the right part. However, if the GPU is soldered to the motherboard that would require a motherboard replacement which is by far not the easiest thing to replace and it will be costly.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Joe McKinnon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 422
