USB iPod jack repair
How do I fix the center console USB jack in the 2012 Quest?
Esta é uma boa pergunta?
Could you post any picture of the port and/or the center console? I'm not familiar with the Quest specifically, but typically the cup holders themselves just pop out from pulling straight up on them. I’ve replaced the Aux port on other Nissans, however. With the cup holders out of the console, you can each up inside the console and squeeze the two retaining clips on the the Aux/USB port “assembly” and push it up. The angle can be pretty annoying on some of those cars, hopefully yours is easier. Let me know if this isn’t the case on your car and I’ll try tot guide you better with the pictures you post. Good luck!
Esta resposta foi útil?
This is my exact setup. https://www.youtube.com/watch?v=x_ve6PhJ...
The video doesn't show many angles of the console itself. Did you try pulling up the cup holders?
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 22
Duração total: 2,720
3 comentários
I know that this is a DIY site but because of how new this car is have you checked in with your local car repair shop about this? Did you ask how much it would cost to repair/replace this USB port?
por [deleted]
What seems to be the problem with the USB port? Is it physically loose or is it not charging your device?
por Travis
My daughter broke the USB port. I need to replace it but not sure how to get the old one out?
por Craig Ogden
