Ir para o conteúdo principal
Different APN on battery replacement
Hello,
So I have an iPhone 6s Plus and I wanted to replace the battery. I ordered an APN 616-00045 but got a 616-00042 instead. I only noticed after one day of the phone slowly not charging past 85%.
Do different APNs matter?
PS - I contacted the store and I’m waiting for a solution.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There is no difference both work, probably is a bad battery or an issue on main board.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Probably just the battery. I sent it back. After that I placed the authentic Apple one and everything was fine, it charged normally to 100%.
por
So I got the replacement and it charges sooooo slowly!!! What the f is wrong?!
por
Sounds like bad replacement batteries from the supplier. Might want to check how much amps the phone is pulling with a USB ammeter which you can buy on eBay.
For 6s plus if I remember correctly it'll pull around 0.67A-1.7A from a good wall charger and cable. Once it reaches around 80% it'll start trickle charging so less than an amp.
It'll be limited to 1 amp on many aftermarket cables.
It'll take around 1-2 hours to charge the battery from flat.
por
Adicionar a sua resposta
Anastasia Tsiga será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 988
