Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
My left shift not working. How do I replace uppercase?
My left shift key not functioning and was advised to replace uppercase. Can you guide me to solution?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Here is the IFIXIT guide to replace the uppercase: Substituição da estrutura superior do MacBook Pro 13" com tela Retina de meados de 2014. Replacing the complete case may not be needed! You can replace the keyboard alone if you’ve got the patience. You still need to follow the same guide just instead continue to remove the keyboard following this video How to replace keyboard in a MacBook Pro A1502. I find once you get the edge up a good pull will yank out the rivets with the backplate. I’ll admit this is still a big under taking more so if you are replacing the keyboard. Its not something I would recommend for a first timer.
Esta resposta foi útil?
Pontuação 2
If you are comfortable with lots of teeny tiny screws then you could just replace the keyboard rather then the upper case itself.
https://www.amazon.com/Odyson-Replacemen...
Replacing the keyboard should be very similar to what is done in this video
If you are not comfortable with lots of tiny screws then you will be better off just replacing the top case as you were advised to.
MacBook Pro 13" Retina (Late 2013-Mid 2014) Upper Case Assembly
Imagem de Replace an aluminum Upper Case Assembly compatible with the Late 2013 to Mid 2014 model A1502 MacBook Pro 13" Retina laptop. Includes the backlit keyboard and may include the trackpad and trackpad. Part #661-8154.
Produto
$149.99
Pontuação 1
Adicionar a sua resposta
Dr srinivas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 100
