Ir para o conteúdo principal
O PlayStation 3 Slim é a segunda versão do console PS3 com o primeiro número de modelo sendo CECH-2000. Produzido pela Sony Computer Entertainment, ele corrigiu muitos problemas da primeira versão do PlayStation (Fat). O Slim foi lançado no dia 1 de setembro de 2009.
466 Perguntas Visualizar todos
Any way of removing the Blue Screw of Death on a PS3 Slim?
I have a PS3 Slim in which I was going to replace the hard drive on, however the blue screw to get to the hard drive enclosure is so incredibly tight that even with the most amount of force I can muster, I cannot, for the life of me, turn this screw even a bit. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Try putting a towel with a lot of grip in between your hand and the screwdriver, hopefully the towel will increase traction between you and your hand. If your driver keeps slipping on the screw, stop trying to loosen it because you will strip the screw. Find a place that has the proper screwdriver for the job and take it there.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you, I will try this as soon as I get home. Would using a pair of pliers around the screw be useful, or should I avoid doing that?
por
@solbady If the acrew is made out of zinc definitely do not do that but if it is steel then that might work.
por
Pergunta mais útil
I would take it into a hardware store and make sure you have the correct bit. You might need an impact driver or just more brute force.
Pontuação 1
1 comentário:
I will definitely do this if the paper towel solution doesn't work.
por
Adicionar a sua resposta
Jordan Schivek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 28
Duração total: 1,736
