Ir para o conteúdo principal
O controle do Xbox One foi introduzido em 2016 com o lançamento do Xbox One S e adiciona suporte a Bluetooth para Windows 10/11. Este controle corrige muitas das falhas de design encontradas nos modelos 1537/1697 e é muito mais confiável. Este controle foi substituído pelo modelo 1914, que é aprimorado.
Soldering station temp setting
What would be the best temp setting for the soldering iron on a soldering station to do some soldering work on the xbox one wireless controllers?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
I keep mine set a 700 degrees Fahrenheit. You shouldn’t have to leave the iron in place for too long to get the solder to melt. You might also want to get some flux. Using flux will help the solder flow and make the whole process easier. This is great whenever you’re working on modern electronics since manufacturers use lead-free solder these days, which is much harder to melt. I recommend using 60-40 lead-rosin solder. Good luck with your repairs/modifications!
Esta resposta foi útil?
Pontuação 5
7 comentários:
Thank you very much for the info. I will give it a try
por Compartilhar
My soldering station will only go as high as 480 degrees. Is that to low? If so what soldering station would you recommend or if that is ok could I just heat up new solder on top and re- desolder from the motherboard?
por Compartilhar
If your station stops at 480 degrees that is probably in Celsius, which is about 900 degrees Fahrenheit. The station I use is made by Weller, which is very good and pretty affordable. If you set your station at about 370 degrees Celsius, you should be fine. What repairs/mods are you trying to make to your controller?
por Compartilhar
Just changing out the motherboard and daughter board
por Compartilhar
How long does your average solder take when it’s 700°F? I’m only starting out and will be slower than you but I don’t want to burn anything by keeping the iron on for too long
por Compartilhar
Exibir mais 2 comentários
Adicionar a sua resposta
Rodney Brookshire será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 60
Ao todo: 9,541
