Ir para o conteúdo principal
ASUS ZenPad S 8.0 was released in August 2015. Model number: P01M with Intel Atom Processor Z3530
Why the tablet would only charge when it is on?
My Asus Zenpad  would only be charged when it is on. I have used the factory cable and charger (adapter) and also used others. the result is the same. It would charge when the tablet is on; it would not charge if the tablet is off.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi this could possibly be a battery or charging port issue. I would check the port and see if there are any bent pins on the inside of the port.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
phil philirvine será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 147
