What does error f2 mean
Every once in awhile the dryer will run and then it stops after about 5 minutes with a code F2 after it sits for a while it will restart what is the problem
Esta é uma boa pergunta?
F2 flashes when there is a stuck button or user interface mismatch. You can try performing a hard reset to fix the problem.
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 99
Duração total: 6,703
