Ir para o conteúdo principal
Repair guides and support for the Huawei P9 Lite, released in April 2016.
74 Perguntas Visualizar todos
Problem with screen colored lines
Hi!
My phone has a strange, purple-and-white colored band on the lower part of the screen. I can still use the touch buttons, even if I can’t see them anymore under this band. The colored line is about 1,5cm (0,5 inches) wide, and there is another larger band 2cm higher. This second band is only slightly darker than the rest of the screen, and I can reed through it very well.
EDIT: I haven’t dropped my phone. The band started as a thin line, than in a week it grew to 3-5 lines and than after another 5-7 days it changed in a full-bar.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you dropped your phone recently or anything, as it could have caused damage to the screen, replacing the screen should resolve the problem however.
Esta resposta foi útil?
Pontuação 0
1 comentário:
No, I haven't dropped my phone in the last year. The phone is in pristine conditions, apart from this problem.
por
Adicionar a sua resposta
Filippo Oliveri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 633
