Ir para o conteúdo principal
iPhone 6s main camera not working
I just turn on iPhone 6s today and my camera's are not working. All I see is a black screen and I can not take a picture. Is anyone else having this issue? Does anyone know how to fix this problem? Can it be related to using it at heavy rain? The front facing camera works fine but the back facing one does not. When I attempt to use in something like facebook it says camera failed to load.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
It can be surely related to unusual circumstances like rain when nothing else special has happened to the phone previously, water manages to get more or less everywhere. Since it’s clean distilled water maybe it didn’t do any major damage to the logic board..try removing the screen and camera to check if there’s any humidity trapped there in the connector. Try letting it dry at open air, possibly a dry ventilated place for a day, you can also blow some moderately warm air with a hair dryer. Then try again if camera works, if not buy a replacement part..if yet it stays black it’s likely some component got shorted and needs replaced, but that would require microsoldering skills and tools.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Ron Bronwick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 168
