Ir para o conteúdo principal
Lançado em maio de 2012, identificado pelo número de modelo J2011-03-US.
My Jawbone Isnt Responsive To Me With Or Without Charger
When i hold the button on my jawbone speaker it doesnt turn on or light up, i plugged it in and nothing all i got was a very quick flash of red and i tried to turn it on while it was on the charger still nothing, i listen to it all the time what has happened
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly you likely have a dead battery or the micros USB connection is bad. You can find the needed battery, but the micro USB socket part is hard to find as Jawbone is out of business. Some people have managed to fit other sockets with a bit of work. First test your battery following this guide to get to the leads: Substituição da bateria da Jawbone Big Jambox if the battery is dead then you’ll need to replace the battery and you’ll then need to check the charging logic as well.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Al-Terrah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 259
