Ir para o conteúdo principal
Repair information for non-Apple computer keyboards.
P key only works in caPital not lowercase
one day a couPle weeks ago my P key stoPed working and i have tryed to use different keyboards uPdat drivers and i just can figure it out
Esta é uma boa pergunta?
Pontuação 3
6 comentários
It is a Windows 10 pro desktop it works with either shift not caps lock it works in the bios caps lock shift P doesn’t work I am typing this on my phone so I have the p. It is a wired keyboard it isn’t the keyboard it has the problem wit any keyboard you plug in or connect
por
Hey! I have this exact Problem, did you find any fix for it??
por
Still any fixes? I'm having the same problem on a Logitech keyboard with the letter V. "Shift v" gives nothing ... "CapsLock v" gives me V.
por
Same problem, but it's my C key
por
Oh okay, I was playing with Geforce Experience's keyboard shortcuts when this happened, as Arthur Dent said he accidentally binded the key to a snapshot keybind, everytime i pressed C it changed the game filter mode.
por
Exibir mais 1 comentário
Adicionar um comentário
5 respostas
Solução escolhida
Strange thing is I found the solution by accident….I was pressing the ‘s’’ key trying to get it to work and it displayed a snapshot on screen, to cut a long story short a program game capture by elgato had the ‘s’ key assigned to snapshot, so wouldn’t work if the program wasn’t running…..so just removed the shortcut…..so suggestion is to try I save mode, use task manager to close all running tasks…..se if it works then…..or try booting into troubleshooting mode, hold Shift while rebooting ( I think that’s how ) & Open a cmd prompt and try typing ‘p’ in there……good luck
Esta resposta foi útil?
Pontuação 6
11 comentários:
Is it resolved now Jarod ?
por
Arthur ... thank SO MUCH. It appears my problem is similar to what you described .... associated with what I believe is a shortcut connected to the Pandora App. Recently I noticed a volume control box that was appearing on my desktop without any intended action on my part. The appearance of this control box seemed to align with my downloading the Pandora App and the start of my "Shift v" problem. I haven't been able to find a Pandora settings options for shortcuts, but at least I have an idea of where the problem is originating.
por
I used task manager to shut down all running programs. I'm still seeing the unwanted volume control box. I have about 130 background process running ... nothing jumps out as a potential culprit for the unwanted volume control box and "Shift v" problem.
por
suddenly could not use lower case M, article suggested app download might be problem, sure enough Free music recorder proved to be problem, mmmmmmany thanks
por
I had the same problem with my ‘a’ key. I found a program running ,that when I stopped it, I was able to use my a key. Hope this helps! :)
por
Exibir mais 6 comentários
A bit more detail would help us round here. Firstly, is this a laptop keyboard, or a separate (wired or wireless) keyboard? If its a separate keyboard, does it work with a different computer?
So lower case p doesn't work. So you get P if your press shift-p? Does it make a difference whether you use the left or right shift key? And CapsLock p gives P? And does CapsLock shift-P give p?
Certainly very weird as you've described it. Could it be a software problem? Does p work correctly in a pre-boot environment, e.g. if you go into the BIOS and find a text field you can type in?
Pontuação 3
1 comentário:
It is a Windows 10 pro desktop it works with either shift, not caps lock it works in the bios caps lock shift P does work I am typing this on my phone so I have the p. It is a wired keyboard it isn’t the keyboard it has the problem with any keyboard you plug in or connect
por
I had the same issue with the lowercase d. Oddly enough, the hot key was mapped to Cntl+Shift+d, but when I deleted that hot key, the lowercase d worked again.
Pontuação 2
1 comentário:
THANK YOU! I will try this.
por
My roommate is currently having this issue if anyone is still around....
he is having an extremely difficult time within our position as we type emails very often and the capital "C" will intermittently work but most of the time it will not.
Unfortunately, he is blind and did not catch this for a long time as his screen reader JAWS was still repeating to him that the keystroke for "C" was made, but it was not there for him when he highlighted the full word, and the screen reader spelled it back to him without the needed "C" no matter the position in the word. he is having to use a little "c" in place but most of our acronyms are in capitol as well as names/locations and addresses, ect.....
he uses Perfect Keyboard, JAWS and a little bit of a desktop monitor (I can't remember the application at the moment) just to center his mouse cursor. This issue is happening no matter what keyboard is connected, but it does work on the laptop keyboard... it is a work laptop, dell Inspiron, with Avaya softphone, notepad++, and office applications. I don't think there is anything within our company software that could interfere with this.
has not always been happening either! just randomly, intermittent and extremely frustrating as one could imagine.
Any advice, Tips, resources? anyone we could contact and maybe have on the phone with us to walk through? hes the brains of the operation but I help visually.. I just CANNOT seem to find the answer within the great-googly-moogilie.....
Pontuação 0
Hi i solved this as i had asus hotkey strating with ny pc. deleted it. and now all is good.
so for everyone, open a CMD windows test you key, if it works hat means you have a software that is bothering you
Pontuação 0
Adicionar a sua resposta
Jarod Richmond será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 92
Ao todo: 8,818
