Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778. Disponível em GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto e Preto Brilhante.
Activate issue with no network works
Hello!
I have iphone 7 (A1660) with (NO service) problem , I tryed use ipcc files but carrier still Not Available, so I update to IOS 12 and now I stuck with activate issue(there is still no service,Even with use different sim cared), it saying Unable to Activate An update is required to activate your iphone. image below
Imagem
I Noted when I eject the tray of sim cared, my phone do’s not say (No SIM card inserted ).
pleas help me!
Thank you before!!
Ibrahim
Esta é uma boa pergunta?
Pontuação 15
1 comentário
I have same problem too
por
Adicionar um comentário
8 respostas
Pergunta mais útil
I solved that issues by changing BBPMU IC on iPhone 7 and restore via iTunes then my problem solved.This videos help me to find the solution.Hope this works.
Esta resposta foi útil?
Pontuação 3
3 comentários:
where is the video? I really need your help sir, I got this problem for a month now
por
where is the video
por
@aresmuzamel
@MAKE
Click on solution to get video
por
This is a known issue with the iPhone 7 modem. Send in for repair with Apple: https://www.apple.com/support/iphone-7-n....
Pontuação 2
1 comentário:
Apple says the fix it for free until you send them the device. I had the same issue and Apple says that my iphone needs a new screen due to a very little scratch and they are charging me 316+tax for that, so they fix the activation issue. Bottom line, they fix everything with the phone or nothing, you have to pay for the cosmetic issue so they fix the activation issue for "free". Scam
por
I had this issue with iPhone 7.
Did a chat with apple representative and they had me go to my iTunes and make sure I was updated first. Then turn phone off and connect to computer. Then open iTunes and let it install update.
It didn’t work.
She next had hold down the power and volume up button for about a minute or two until your phone shows that it is connected to iTunes, then the iTunes screen on my laptop was showing that it was extracting, then when it was done it started to update.
Phone turned off after installing and I was able to set my phone up.
Pontuação 1
some people with this case get their phone back with changing baseband power ic on the machine board. May be y’all wanna try it too.
Pontuação 0
ich habe problem men iphon gleich ist was maen bite
Pontuação 0
if the model is of those : A1660, 1680 , A1779 then there is no issue coz apple said it, you can read this link :https://support.apple.com/iphone-7-no-se...
Pontuação 0
Fixed by adding another device to my account(iphone 6) then i removed my iphone 7 from list of trusted phones. That allowed me to activate.
Pontuação 0
1 comentário:
could you explain it a little bit more?
por
My iphone 7 unable to activate
Pontuação 0
Adicionar a sua resposta
Ibrahim Hassan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 21,985
