how do i get architecture back
trying to install driver into the terminal with a command line
now when i try to open the terminal it says it cant open because it is not supported by this archetecture meaning applications
Esta é uma boa pergunta?
What file did you move, rename or delete?
Can't help from such scant information.
N.
Esta resposta foi útil?
i was in aplications/utilities/terminal
i accidently deleted the information in the contents folder
now when i try to open the terminal it says not suported by this archatecture
thats where i am now please help
all because of ethernet adfapter
== You need a new copy of terminal... == if you have install DVD/CD you can use [http://www.versiontracker.com/dyn/morein...|Pacifist} to extract one and drop it into Utilities.
Get the proper flavor of Pacifist for your OS.
Good Luck,
N.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 696
1 comentário
you appear to have 3 questions about drivers all posted within a day or so - I assume it's all a related issue. instead of posting 3 separate questions (including this very vague one) you should post follow ups to the same original post
por bac
