Ir para o conteúdo principal
My phone keeps freezing
I’m having a problem with my phone. It will freeze every little bit and in order for it to work again I have to turn my phone off then back on again and it works fine but then freezes again after a while.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Here’s a helpful article: https://www.appleworld.today/blog/2015/8...
The comment from Lloyd Shepherd might be the first thing to try: go to settings > general > dictionary and uncheck unnecessary dictionaries.
If it’s not spell check related, then it may not actually be freezing but rather becoming unresponsive to touch. If that’s the case, see Pam’s comment: “I read on a UK site that iPhone 6 can have a touch screen problem and recommended placing a coin just below the camera and inside a hard case to prevent a touch control from bending. Sounds odd but I did this and phone has returned to working order”
If none of that works then try to think when this started happening or what might be triggering it. An iOS update or a certain app might be causing your trouble.
Hope this helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
deidre2002 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 96
