Ir para o conteúdo principal
A general-purpose audio device that transmits low audio frequencies to your ears.
What is this burned piece called
Punched my subwoofer cuz it wasnt working. I think it had blown voice coil. Semi worked then a few days later my stock amplifier from my 08 Mitsubishi lancer gts started smoking from under my seat. I took it out and opened it to find this. Can i take this piece out and fix it with a new one?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Brian .... that is the power amplifier IC
are you good in soldering, for this .... If you have a hot air…. desolder it, note the part no and order replacement.
some idea for you to read……
e.g. troubleshoot, inspect, etc.
http://jestineyong.com/two-ics-burnt-in-...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Brian Mcqueen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 140
