Ir para o conteúdo principal
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
Impossibile visualizzare l'opzione Wipe data / Factory in modalità di
Hi everyone, Please help me. I thought, once I entered recovery mode, I will use Wipe Cache to reset my Nexus 5X.
When I enter this mode, I do not get anything like that. I use the following guide to access the recovery mode:
https://techshali.com/enter-recovery-mod...
I am sure these options should be there in the recovery.
I have to flash custom restore or anything that could be done.
Any help is appreciated
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi ,
What are you getting when you try to enter the Recovery mode?
Are you pressing all 3 buttons together (i.e. Volume Up + Volume Down + Power) to get to the option to select Recovery mode?
por
Adicionar um comentário
1 resposta
Almost sounds like you are getting the “No Command” android guy:
From this point you would hold down the power button and press volume up. Then you would enter the recovery menu where you can factory reset the device.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Deepak Gupta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 117
