Ir para o conteúdo principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Perguntas Visualizar todos
two broken 30-inch cinema displays hoping to make one working
Hi,
I have one with short-short-long blink issue (display 1)and one with blank display (display 2)but the led is not blinking (continuously on).
how would you move on to make them into one working 30-inch Cinema Display?
display 1 shows an image when doing the flashlight trick against the screen.
display 2 doesn’t
thanks for your advise
Esta é uma boa pergunta?
Pontuação 0
5 comentários
@mayer This might be a good one for you sir.
por
What are the Axxx numbers from the bottom of the stands? It may look like A1407.
por
A1083 on both displays (30 inch)
por
Apple Cinema Display 30-Inch (Aluminum) Specs
Identifiers: Aluminum - M9179LL/A - A1083
por
solved : I took the inverter board form the display with continuous led (no blinking led) and put it in the display with short-short-long and works perfectly now
por
Adicionar um comentário
1 resposta
Solução escolhida
short, short, long
The display is detecting a backlight error. Check your display's power connections and restart the computer. If the problem continues, contact Apple or an Apple Authorized Service Provider.
Well Apple is not going to help you.
Lets go for the cheapest repair first, with it on, hold a flashlight at an angle to the screen and see if you can discern the desktop. If you can, replace the inverter.
Apple 6632L-0416A A1083 30 Cinema Display Backlight Inverter Board LGIT-LM300W01
UPDATE
The serial number with bar codes is located on a label under the foot of the display. To view the serial number, hold the sides of the display and gently lay the display face down on a soft, clean towel or cloth.
input that number her to identify your exact machine:
https://everymac.com/ultimate-mac-lookup...
Esta resposta foi útil?
Pontuação 2
5 comentários:
will try that
thanks
por
do you know a way to test if the inverter board of display 2 could be good?
por
do you know where to find the service manual for the A1083?
por
how to know which version the 30-inch is? I guess they have different inverter boards. is it possible with the serial number? saw they can have 2 or 4 pins depending on the version but not totally sure
por
fixed! short-short-long led was broken inverter board so took it from a display with continuous led(no blinking but black screen)
por
Adicionar a sua resposta
Perry zelck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 928
