Ir para o conteúdo principal
TI-84 Plus calculator support.
33 Perguntas Visualizar todos
My calculator turns on but unresponsive to the keyboard.
My Ti-84 turns on but when i press the keyboard its unresponsive. The cursor just keeps flashing and the none of the buttons work.
Esta pergunta é pertinente?
Pontuação 4
1 dos comentários
had you tried removing the backup battery and 4 x AAA battery?
leave it for some time. I had one unit having this issue too....
I notice there are several hardware revision and what firmware are you using?
por
Adicionar um comentário
1 Resposta
Solução escolhida
Augustine has a good suggestion, try removing the AAA batteries and the backup battery, then try replacing them. If any of them are corroded, they may have permanently damaged the buttons.
If that doesn’t help, here’s a guide on getting to the keys that may help. Once you’ve gotten to the main board, check for any loose or dirty connections.
If you find the buttons are beyond repair, you can buy a cheap, used calculator and swap out the motherboard.
Imagem de TI-84 Plus Silver Edition Backup Battery
Guia
TI-84 Plus Silver Edition Backup Battery Replacement
Nível de dificuldade:
Fácil
3 - 5 minutes
Imagem de TI-84 Plus Silver Edition Motherboard and Screen
Guia
TI-84 Plus Silver Edition Motherboard and Screen Replacement
Moderada
5 - 15 minutes
Imagem de TI-84 Plus Silver Edition Keyboard Mat
Guia
TI-84 Plus Silver Edition Keyboard Mat Replacement
Moderada
10 - 20 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jerin7931 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 92
Duração total: 7,536
