Ir para o conteúdo principal
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
46 Perguntas Visualizar todos
Why is my control stick in a pushed state, how do I fix it?
umm hello, my controller stick seems to be pushed into the incasing of the controller. The stick doesn’t move around that greatly as the stick’s rubber thumb grip rubs against the case. Can’t seem to find anyone else with this issue on the internet. Could anyone help out?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Well, if that is the case you may want to replace the joystick. iFixit provides a guide on how to do that, and you may want to upload some images of what it looks like inside of the controller so we can deem if your controller is reusable or not.
Nintendo GameCube Joystick Replacement
Adding Images to an Existing Question
Imagem de Nintendo GameCube Controller Joystick
Guia
Nintendo GameCube Controller Joystick Replacement
Nível de dificuldade:
Fácil
5 - 6 minutes
Imagem de iFixit
Guia
Adicionar imagens a uma pergunta já existente
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Issac Oh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 171
