Ir para o conteúdo principal
Sim card ejection tool accidentally inserted in upper mic.
Hi,
i accidentally inserted the sim card ejection tool into the upper microphone hole while trying to replace the sim card. i felt a jerk (like the tool tore or broke something), i have tested my microphone and it works just fine, however, i am worried if i have broken or damaged the waterproofing of the phone. i observed the performance and any damages to the microphone for a week now and everything seems to work fine.
the only concern i have here is if my phone’s waterproofing is damaged.
Thanks,
Danish Khan.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Pergunta mais útil
My guess is NO. :)
I have a couple of opened up S9 (not S9+, which is why I’m only guessing) and the water seal is placed to the side of the hole where you would have inserted the tool. I put a tool in there and wiggled it around and could do nothing to the seal.
Also, the seal is very delicate so even if you break it, you would not feel it, so I have no idea what the “jerk” you felt might be.
So again, I guess you didn’t damage the water proofing but, just in case, don’t go swimming with the thing. ; D
Esta resposta foi útil?
Pontuação 4
4 comentários:
you can see the seal in this image on the tear-down.
https://d3nevzfk7ii3be.cloudfront.net/ig...
see what I mean about the seal being on the side and not at the end of the hole?
por
Thank you so much Santiago Alfaro! Your answer and the picture gave me relief. I was worried as i just bought the device and it happened.
por
Hi Santiago! Thank you for the great response to Danish! Do you know if the bottom mic is placed to the side of the hole as well? I had the same thing happen with a SIM tool + the bottom mic on my S9+.
por
Hi Kevin.
Yes. you can see the image on the tear-down here, https://d3nevzfk7ii3be.cloudfront.net/ig...
now, remember all the same caveats that I said to Danish, they still apply.
good luck.
por
Hi Santiago…i recently purchased Samsung Galaxy S10+ and by mistake I inserted my Sim tray ejector tool in the mic hole which is located at the top of the device…will it hamper my device in a any ways?? Please help.
Pontuação 0
1 comentário:
Could I get a link showing the breakdown pictures of the device Samsung galaxy s10+ along with the actual location of the mic and it's component
por
No this will not effect the water proofing at all as long as you din’t stick it deep.
Pontuação 0
Hi Santiago I recently purchased Samsung Galaxy S10+ and by mistake I inserted my Sim tray ejector tool in the mic hole which is located at the bottom of the device does this affect on water resistance mic still works.
Pontuação 0
1 comentário:
Hi Jyri, did you know at the end whether it did or didn't compromise the water resistance? I feel like this is being done intentionally by Samsung, they could make the holes smaller but no they make them the exact size so mistakes like this could easily be made.
por
Hi everyone . I did the same to my galaxy a70 . Is there anyway i can check if i have broken anything or not ?
Pontuação 0
1 comentário:
everything is safe, Nothing can be happen while puting Sim card ejection tool in upper mic port
por
Adicionar a sua resposta
Danish Khan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 7,531
