Ir para o conteúdo principal
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76 Perguntas Visualizar todos
Top RAM Slot is not functioning
Hi, I´ve recently bought 2x8gb Ram from OWC following their instructions to order the correct one. tried to install them but when I boot the mac it keeps restarting by itself. I´ve tried both rams separetly, and both working, I´ve finally found that the top ram slot is the one causing problems. The weird thing is that originally I had 4gb and 2gb on the bottom and top ram slots (6GB in total) any idea? any tips?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Try using a lessor stick in the upper slot, leave the 8 GB in.
I use Micromats Atomic to test RAM:
https://www.micromat.com/products/atomic
Esta resposta foi útil?
Pontuação 1
6 comentários:
By lessor stick, I means a 4 GB and 2
GB stick.
por
Hi @mayer @mayer, thanks for getting back to me so quickly. Could you please rephrase the answer?
Use a lessor stick on the top slot? Sorry not sure what this means.
I can buy atomic software and test the ram, although both ram sticks works on the lower slot…
Many thanks for your help.
por
What OS X are you running?
Originally, both the official and actual maximum RAM was 8 GB. However, as confirmed by site sponsor OWC, if running OS X 10.7.5 or higher, updated with the latest EFI, and equipped with proper specification memory modules, this model can support up to 16 GB of RAM.
por
@eduhecam What Mayer means by use a lesser stick is to use a RAM stick with less amount of RAM (like let’s say a 4GB or 2 GB instead)
por
Thanks @ajcooke01 . I've tried. Worked for 5 mins, 8gb + 4gb at the top (different brands same ram specs) But I've got the spinning wheel, and then completly freeze computer...
por
Exibir mais 1 comentário
Adicionar a sua resposta
Eduardo Hernandez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 373
