Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
8+ stuck on logo/loading
My partner attempted his first 8 plus lcd replacement. He is now no longer allowed to attempt phones lol. The phone stayed on the logo screen and would go blank once in a while when powered back on. Tried disconnecting and reconnecting it all. There seemed to be issues with his transfer of the earpiece/front camera so we tried a different lcd with earpiece and camera built in and transferred the home button from the original screen. Same result so tried the volume up, down, side button and connected to iTunes for an update. Now phone is stuck in a loop of loading on the logo screen even when disconnected from iTunes and the PC. Is there a solution or some suggested fixes to try???
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
On startup of both the 7 and 8 series iPhones, the phone will run a self diagnostic to be sure all hardware is working correctly. Normally the front camera assembly and home button are the easiest to damage during the repair. Since you have already tried a new lcd and front camera, I would imagine there could be some damage to the home button. Unfortunately there is no home button fix besides going to Apple and having them replace it.
I haven’t heard of it happening with the 8, but the 7 series has had issues with the audio IC which has delayed or prevented startup. It could possibly be something like that as well.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Reboot Tech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 147
