Ir para o conteúdo principal
Released March 2016, 7.0" Galaxy Tablet by Samsung.
Media sound not working? SOLVED
Media sounds not working. Notifications & system sounds are fine.
Esta é uma boa pergunta?
Pontuação 13
9 comentários
Thanks for the input guys. It's loud & proud again.
por
It's working again. Needed some down time I suppose. It's loud and proud once again! Thanks
por
Sounds goes up and down by itself
por
I have a problem of my new tablet A. It has no sound, i can’t hear any voice . All is set in settings but still no voice
por
I waited on my comment to be answered..
por
Exibir mais 4 comentários
Adicionar um comentário
3 respostas
Pergunta mais útil
Also another thing to check is to make sure you do not have do not disturb turned on or turned on as scheduled. Depending on how it is setup it may mute all media sounds.
Esta resposta foi útil?
Pontuação 4
2 comentários:
Thanks. It started working after I left it off for an hour.
por
Thanks... checked and it was my “Do Not Disturb” mode was on. Don’t know how it got enabled but it was in and fixed my problem.
por
If your tablet is anything like mine when you hit the volume keys there is a dropdown, maybe the media tab is all the way down.
Alternatively you could have somthing wrong in the system. I had a problem like this where i had to go to a boot menu and clear some temporary data on the
Pontuação 1
1 comentário:
Thanks. It started back up after I left it off for an hour.
por
Make sure it is not connecting to a Bluetooth device
Pontuação 0
1 comentário:
Thank you thank you thank you Malcolm, that was the solution for me. My tablet was connected with my hearing devices, which lay around somewhere in the living room.
por
Adicionar a sua resposta
Richard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 102
Ao todo: 23,333
