Ir para o conteúdo principal
Budget notebook laptop made by the Toshiba Corporation and released on January 17, 2010 tailored toward college students.
5 Perguntas Visualizar todos
Laptop won’t turn on
I have a Toshiba satellite l505d, at first when I hit power button lights and fan turn but not screen no boot up, I tried a few times and it will start, but no metter how manny times I tried it don’t don’t start
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Does the disc drive start moving with a disc in it? If it stays powered with the fan on I doubt its anything to do with the power supply. It could be a loose LCD flex cable, laptops tend to have LCD connection problems after years of use. Try connecting it to another monitor with a VGA cable if it has a VGA output to project to another screen. If that works then its the LCD or the flex connection. If not then it could be a fatal motherboard issue.
Esta resposta foi útil?
Pontuação 0
sometimes they overheat, I have inspected some and they have heat marks
Pontuação 0
Adicionar a sua resposta
Fernando ullola será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 329
